Solas Dual Impeller + Tunnel Seal
dailyderbi
195S
Finally got my Solas dual impeller on and sealed up the intake tunnel on my 195S.
A bit of background here. I live south of SLC, Utah and the two local reservoirs I boat at are 5,500 ft (Deer Creek) and 7,500 ft (Strawberry). I also make at least three trips a year down to Lake Powell, which is about 3,650 ft.
Cavitation on the stock impreller at these elevations was really terrible, especially when towing anything. So after quite a bit of research, I've done three things:
  1. Installed a Solas Concord dual impeller. There's a lot of talk about these but nothing around the actual results. Once I get it on the water, I'll update this thread and let you know. In theory, these dual impellers are suppose to eliminate cavitation, plus Impros did a customer pitch for 5,000 ft elevation (happy medium between local destinations and Lake Powell). I don't care about top speed, just power for wakesurfing and tubing.
  2. Got a REVA filter to replace the stock one. I was shocked at how little surface area the stock filter had compared to the full open RIVA/K&N one. Especially for being a supercharged motor, I would have imagined as much clean air intake as possible would be best. I did install this before my last outing and can tell a very big difference at higher elevations. The punch on the low-end RPMs is much more pronounced and quick.
  3. Sealed up my intake tunnel (not the most beautiful of jobs). Interestingly, the dual impeller blocks some of the back areas that I had intended to seal (and probably more high-impact to reducing cavitation), but I'll have to do it the next time I pull the pump. Definitely makes for an interesting photo to see the impeller sticking out twice as far as the stock.
Next time I take her out (will be a couple of weeks), I'll follow up and let you know how all of this translates into higher elevation cavitation.
Very interested to hear the results of your water test, may I ask the part number of the Solas?
Thanks
I'm at sea level, but, like you, I care a lot more about low-end punch than top speed.
Do you think the air filter alone would make a difference at sea level?
Yes, I do! Take a look at the difference between the two and you can see just how much more intake space there is:
- RIVA: https://amzn.to/4djWJVb
- Stock: Amazon.com
It's also not the most expensive upgrade all things considered, so even if it doesn't totally change your boat, it's worth the price for the incremental performance upgrade.
Thanks!
Following, looking forward to your updates after getting it on the water!
Post those results!
Ping on this post - how are the twins working out??
Sorry, no update yet. Haven't been able to get the boat out. Kiddos soccer season started and free time on the weekends has gone to crap.
Did you ever get the boat out to determine difference with the twin impeller? I’m also in Utah and need to re- pitch due to out elevation so very interested in your results.
Here is a thread you might be interested in on the subject
Unfortunately, I haven't really had the time to test it. I did take it out for a quick 5 minute spin on Utah Lake to ensure that it was installed correctly. That very quick runabout showed me three things:
  1. It does, indeed, have WAY more get up and go. Hole shots feel like they're getting a bunch more bite now.
  2. On the no wake mode, in highest setting, it vibrates like crazy. Not sure what this is. Could be my tunnel sealing...? It's annoying AF though and almost enough to want to go back to the regular impeller if I can't get it to sort out.
  3. It's super loud. Between that and the K&N filter, the boat is really noisy. I'm not sure the kiddos or the wife will want to put up with it.
That said, I need to actually do much more testing. But as of yesterday, I've oil changed and fogged my boat, got it on scissor stands in the garage and called it a season. So testing will have to wait for a few more months.
