haknslash
- Lake Martin, AL
- Moomba
- Other
They show some surf footage in the new boattest.com video
Cool features but I agree, surfer was pumping big time. Boat needs another 1,000 lbs of ballast.Looks like the surfer was doing a LOT of pumping to keep up w/the boat. . . . .
You're right, surfing in a circle is not the ideal... With the minimal stock ballast it's pretty much the necessity of you want enough push to go ropeless. Even then it's barely adequate and its not pretty. However, as the rider you don't really notice that boat is turning... and any surfing is still fun. SurfPointe may clean it up a bit...?Lol love how they turn in a circle to artificially build up the wave. I think my 192 makes a bigger wave if I turn in a circle. Nobody wants to surf in circles. Not impressed by their SurfPointe "technology".
Has anyone ever taken the measurements and tried adjusting an earlier model boats nozzles to match Surfpointe? Any difference/benefit?
Nope not for me.. Talking with a dealer the other day and he said there is a major decrease in reverse steering with surfpoint.I was just thinking about this yesterday. . . . I vote for @jcyamaharider to test this in conjunction with the wake wedge. ; )
There is a thread on this last year or earlier in this thread where I did some testing. Yes reverse becomes a little reduced especially reverse steering and forward full left or right turns. And yes I did notice a 10% or so increase in wave steepness with the wedge and two of us were able surf at the same time without the wedge. One on each side...
I always get confused when people are talking toe-in on the jets. If you think of it as the same as toe-in on a car then that would mean the front side of the jets are toe-in causing the jet output to be angled out. However, I imagine we are talking about angling the jet output in towards each other which would mean that the back of the jets are toe-in (opposite of a vehicle toe-in setup). Technically I think when angling the jet output towards each other this would be a toe-out configuration (meaning the front of the jets are toe-out and the back of the jets are pointing at each other). Anyway unless someone corrects me I'm assuming we are angling the jets toward each other in a toe-out configuration (seems that only makes sense here). Not trying to be and anal dork about it, just been confusing for me cause I've seen differing toe-in/out terminology used on this forum for things like jets and fins. I suppose some of the confusion may be because toe-in/out maybe isn't even the right terminology to use in the case of jet nozzle angle?? ¯\_(ツ)_/¯ On the other hand maybe I'm an idiot and nobody else is having this issue.![]()
I have. I have an '16 AR240 with ballast. I would fill the port side and locker bags, have everyone on board sit on the port side and perform a gradual turn to port, then back the throttle off on the port side to help clean things up a bit... it worked to a degree... and I was able to go ropeless. I've added the wake wedge this season so it shouldn't be as necessary.Has anyone tried using different rpm's for each engine while surfing? I was out yesterday playing around on my stock 242 limited S and was running the starboard engine hard compared to the port engine around 10-12 mph. This naturally makes the boat want to track to the left, so you have to turn steering slightly to the right to offset. This directs some of the jet wash away from the port side. Just curious if anyone has played around with their set ups using this method.
