I went with WetWolf Adjust-A-Cone instead of lucky 13. It's pretty much the same except for the cost. i dialed it in to what I was looking and am very pleased with the results. Trust me, they DO make a difference.
I just got the Wet Wolf Adjust a Thrust Yam-5. What configuration are you using? Example: The third biggest insert, with two washers, and the longer bolt. I would appreciate any help pointing me in the right direction to start tuning it. Thanks
I started off with the largest cone based on what Bruce said. My goal was fuel economy. My first go round (with the longest cone, longest shoulder bolt) help with top end and my RPMs stayed the same. He sent a longer cone and this reduce my RPM by 200, top speed by 1 but dropped by RPMs by 500/engine. This is what I was looking and stopped. What are you trying to do?
So I took your advice and I ordered a Solas Concord 13/18 Impeller today. I just installed the Wet Wolf Adjust a Thrust and that will help to address the cavitation due to the lower pitched impeller. Once I install the Impeller, I’ll have to tune the cone with the different supplied shuttles to dial it in. I’ll let you know how it goes... Any tips anyone has about the swapping the impeller will be greatly appreciated.
Yes, I did. You will need an aluminum coupler. I have attached the link for the one that I purchased on Amazon. Also, if you look closely at the photo of the filter, you’ll see a stainless steel zip tie for extra support. That’s all you’ll need.
So, I went ahead and purchased the Fizzle Factory Y1000 intercooler and HKS blow off valve for my SVHO. The install went really well and I also removed the stock air box and went with a K&N air filter. In order to make good use of the new mods, I also went with the Maptuner X with the Stage 1 plus tune from Riva Racing.
One of the cool things I did, was to find a better way than tapping a hole in the Intake manifold for the vacuum line to the blowoff valve. I used a 1/4 brass tee and spliced into the map sensor vacuum line. It worked great and I’m looking forward to taking it out for a test run this weekend.
Previously, I was topping out at 53mph and I’m curious what my new top speed is....
Here are some photos of the install.
@SamCF was the one who inspired me after seeing the mods that he’s done..
That is an excellent combo of mods. Should be somewhere around 58 mph with the 8300rpm limiter. 8600 rpm tune and some impeller work should be 60+ mph.
Yes, it’s serves as a cold air intake and has less restriction than the stock airbox. Here’s a link to the two items you would need for this mod. It’s around $40.00 dollars to complete this mod.
Buy K&N Universal Clamp-On Air Filter: High Performance, Premium, Washable, Replacement Filter: Flange Diameter: 4 In, Filter Height: 5.5 In, Flange Length: 1.125 In, Shape: Round Tapered, RG-1001BL: Air Filters - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
Today I installed a Solas Concord 13/18 160mm impeller today. The install was fairly straightforward and surprisingly when I took the jet pump out, there wasn’t a drop a sealant between the Venturi nozzle and jet pump, or the jet pump and the boat. When I put it back together I did use Yamabond 5 between the different sections to seal it up properly.
By far the most difficult part of this whole mod was getting the old impeller off!! I recommend if anyone tries to do this mod that you make sure you heat up the old impeller with a blow torch. You want to heat from the front of the impeller where there’s a slight gap, so the heat reaches the back where the threads are to make them expand off the impeller shaft. Put it this way, I weigh 250 pounds and I had to put all of my weight on it to get it loose, with a friend holding it straight and making sure the spline end didn’t pop out of the vise on my tool bench!! To do the install you’ll also need a 27 mm 12 point wrench to remove the impeller.
Also the OEM impeller looks brand new and I’m going to be putting it up for sale on eBay. It doesn’t have a nick, scratch, dent or ding and I'm sure there’s someone out there who can use it.
I also have a Wet Wolf adjust a thrust that I’ll have to dial in to get the most out of the new impeller.
I’ll let everyone know how it goes and I’m hopeful that I’ll break the 60mph barrier..
So the two different tunes I can select from is the stage 1 plus tune with an 8400 RPM limit or the stage 2 with the 8800 RPM limit. I wish they had an 8600 Listed...
If you can spin 8400 rpm with that impeller, it should put you over 60 mph. I would try the 8400 tune first. They don't recommend exceeding 8600 rpm without valve retainers.
The new impeller is a game changer!! Using the biggest shuttle that was provided for the wet wolf adjust a thrust I was able to hit 61 mph @ 8250 rpm with a half tank of fuel, two large adults, and gear. I know that if I drop the shuttle size it will increase the RPM and then increase the top end. It’s going to take a couple more runs with different shuttles to dial in the cone. I very happy with the results!!
