Under the SeaDek, cleaned them and made sure they were flat & smooth and installed the seadek right over top of them. Not necessary to fill the holes under the seadek according to several of my trusted installers and fiberglass repair guys.
Outside of the seadek, filling and finishing with Marine Tex epoxy. Holes ONLY, just filling them using a toothpick and not gobbing all over the hole. Keeping as much factory finish as possible, for the more natural look.
That's a good plan! The new Yamahas have no wood/balsa core in the deck or anywhere, so there is not much to worry about really.
I have initially plugged the holes with 3M 5200 but it yellows over time and gets dirty - drives me nuts. I'm going to clean the offending holes with a dremel and fill/finish with OEM gelcoat (Spectrum, WC5 - for most new white decks).
So I was poking around Home Depot and noticed the Flex Seal stuff and got me wondering if that would work as good if not better, than the Marine Tex? I believe it can come in the form of white caulk, which could be really slick to just fill in the holes. Anybody ever use that stuff?
Crummy weather today, so finally got around to organizing the boat. Everything finally has a home so no random stuff tossed in various compartments. Few extra life jackets to keep us legal when just out cruising with friends.
I was finally able to pull ours out of storage to put a charge on the batteries and a good cleaning. She was a little dusty since she stayed in a storage facility with a friends jetski instead her home garage. We then put some fresh gas in her and took her for a spin. A beautiful, but windy day.
We got to check out the Sea Ray sitting in her slip before we put the Yamaha back on the trailer.
Yeah, I get to finally be a part of the What Did You Do to your Jetboat thread!!!
This weekend I did the throttle drop fix. The write up with photos was spot on! And honestly, after you take one of these apart, you have such a better understanding of how they operate. And that it's not a hard job. I left mine attached, so I had a harder time just finding a place to rest them while I did the fix.
Thanks for the great write up. We also named and lettered the boat this weekend. Installed two new batteries. Scrubbed all the seats with harsh chemicals, and ran the stereo so loud the neighbors came over.
I also took delivery of my new-to-me Floe 5000lb lift. That will be exciting to dip in the cold water this weekend!
Ribbon delete and tried out the new Mega Fangs. Both made the first run of the season (only 60 degrees out) fantastic! Look at that speed! It is interesting the techs say 8k, but the digital says 7700.
Also found out my center ballast bag pump is seized or fuse blown. **Edit: I found another post where someone couldn't get there ballast to work either and all they did was turn the batteries off then on, and that worked for me too.
I really like it, kind of wish “all” upper deck pads were thick, I think it would look way better.. might have to ask Will @JetBoatPilot and see this option is available.
Over the last couple days I've installed a fuse block (Blue Seas Safety Hub 150) behind the helm with a 1/0 feed and reworked my amp board to accommodate a new 400/4 amp for soon to be installed helm and swim platform speakers. Still need to clean up and tie down the wiring a bit and want to run new speaker wire to each speaker to bypass the OEM. Hoping to get the wire run, helm speakers installed, and install my Raymarine Axiom 7 all this weekend. It's supposed to rain here so I'll have to do some garage boating instead!
On a side note, there is a TON of room under the fuel hatch cover. Why didn't Yamaha use up the space and install a larger fuel tank? I think 75 gallons would fit pretty easy.
I've never had that cover off. That's a lot of room in there. The extra fuel in a 75 gal tank would add just shy of 200lbs of ballast when trying to surf. That would come in handy.
@Crlos16 I love that laser level, what a great idea. I could have used that with mine. BTW I think for your model, the 1" mat makes sense as your crew will be lounging there.
Nice install. I really like that Safety Hub. Might be an offseason project for me to condense my separate high/low amp bus bars that take up a lot of real estate on my board.
Moved the Ski Locker strut so that the door opens more than 45 degrees. Added a couple clips to store the boat hook and VHF Antenna. Excuse the filthy boat, cannot wait for this pollen and non-stop effing rain to stop - she needs a bath.
Big houseboat trip to Lake Powell (AZ/UT) Memorial Day week, so I put a few final touches on the boat.
- Added Plug Locks from Cobra (literally took 5 minutes)
- Adjusted the throttle cables to full stop at WOT.
- Installed 12 volt lighter plug at the back of boat for airing up inflatables.
- Put on foam float tubes on the windsheild for a several hundred mile trip with the cover on.
- Installed LED MR16 docking lights. (No more radio cutting out when turning on the lights)
- Tested all electrical stuff and found the POS horn is dead. Found the Aqua Signal replacement on Amazon.
