HangOutdoors
- Royal Oak, MI
Drove a few hundred miles today and out to an outdoor show, and enjoyed the new ride feeling with new loaded struts all the way around. Can't say enough good about the KYB Struts Plus. Corning is better, firmer than OEM, I equate it to the firmness of an F-150. Truck sits about 1" higher and I also move a trailer with someone boat on it 7000 lbs, with little sag. I would encourage anyone whom needs to replace their rear struts and/or front struts to check them out, well worth a look.
As an aside, I was looking at the Bilstein's 5100. They are nice as well, but only shock comes with it and I would have to compress the existing OEM coil springs, take off the plates and put it all back together. Unfortunately I don't have that much faith in the existing rear coil springs. The KYB loaded Strut Plus has a new coil spring and it is denser. And save a ton of install time.
