- North Caldwell, NJ
Thanks, @Mainah - what can I say? When you right, you right!@swatski I agree that you need a side by side comparison to know if anything was made out of spec or if the spec has a wide tolerance. I still strongly believe the things I said in my only other post on this thread. I see you continue to question whether you did anything to put your family at risk and I do appreciate you laying it out there to bare for the benefit of the community. Do we all do things hastily from time to time? Sure perhaps we sometimes throw a screwdriver back in the junk draw instead of going out to the garage to put it in the proper tool box. Sure we did stupid and risky things when we were younger. We have grown and learned since then so to say that you knowingly or hastily put your family at risk I find hard to believe. When it comes to things I consciously or instinctively know need to be right; I make sure they are right. You like most on this forum just sound like that type of person. Is it possible that you cross threaded the bolt? Sure, but ask yourself if you would have done that out of haste as you obviously did not do that knowingly. If you did do it out of haste you probably would have already remembered and that kind of thing happens but I still don't think that would be you. If not knowingly or out of haste then please consider not beating yourself up.
What happened sucks. This is obviously not a good design and hopefully the design is changed. I have been rather hard on Yamaha in my last couple of posts. Frankly they do deserve most of it. Little things like the voltage issue happen and companies make decisions not to fix things like that due to cost/risk/benefit which is normal for any company. What truly bugs me is that boats should not leak (I have had a slow leak since day one and have finally done the work to figure out it is not just one leak but three and I will be doing a separate thread on that). Boat hardware also should not pose an undue risk to its occupants. In cases where a design flaw, part defect, or poor quality control can pose undue risk to life and limb companies need to do the right thing before it ever leaves the factory. If not caught there (and it should be) then they need to do the right thing after the fact. In the current crop of boats there are too many design and quality control issues to call it normal or acceptable. It is this last point that brings me to once again to why I decided to post again in this thread. What do you find more likely? That you knowingly or hastily put your family at risk or that there are design and quality control issues that played a bigger/vast majority role in what occurred.
I am going to stop whining, what's been driving me crazy is that I literally talked my wife out of an X model (which turned out to have a much more robust tower!)
When the wife says: "honey, get what you want and just make sure it has everything we need" - and you bringing home a lemon... - one should be entitled to do a little bit of whining, right? LOL.
