Ericd
- Illinois/Florida
- FSH Sport
Doesn’t the red hose run to the hose hookups for flushing the engine?
YesDoesn’t the red hose run to the hose hookups for flushing the engine?
Look for that red hose and the Y fitting, but you're going to be clamping the black hose - the red hose is just a visual aid to point you in the general vicinity.
just picked up a 2023 AR195s.. and boy, they made this a near impossible task to do. the access hatch is on the opposite side (starboard) of where the hosing is. I wanted to install a valve so i can flush the engine while in the water if i was going to leave the boat overnight. i'll have to either brake the silicone holding down that entire cover or cut out a section on the port side to install another pop hatch. why make it so difficult to access an area you need to get to during an emergency?
Guys I have been reading all the responses on this matterAs pictured, I'd go with #1. It may be easier to clamp from it from the other side? I plan on installing tow valves at some point. I think it may be easier for me in the transom.
There is no red line protruding thru the bulkhead at the rear of the engine compartment. The red and black line is located within the compartment that has the inlet where you hook up the garden hose.
You would have to remove the large center panel with about 15 screws to access the red and black hose.
Hopefully these diagrams shed a little light. I am dealing with an older tablet so I had to do some old style editing to make them come out. I will try to attach the files and see if it works. These are the diagrams of the water flow for the 2024 - 2025 AR195 and SX195.Try again, guys I have a 2025 ar 195 and none of these areas to clamp off seem to be correct and I can't seem to even get a dealer to explain where to clamp the proper line for towing. #1. There is no red line protruding thru the bulkhead at the rear of the engine compartment. The red and black line is located within the compartment that has the inlet where you hook up the garden hose. You would have to remove the large center panel with about 15 screws to access the red and black hose. This is not feasible if you break down and are being towed. According to my 2024 manual (because they don't have a 2025 yet) the diagram shows the red and black hoses going into an x valve labeled A and B which is in the compartment previously described. Here is the important part, the black line continues thru the engine bulkhead, however the other line exiting the x or 4 way valve goes up to the water pilot outlet and seems to bypass all engine components. It would seem logical that you could pinch off the single black line coming thru the bulkhead at the rear of the engine before it enters the tee, and you would be safe to cut off water flow to the engine. I have not posted the new AR195 diagram yet but will attempt to in the near future. If anyone has more information on this newer design please let us newer model AR owners know, as we don't want to blow up an engine because of a tow. Thanks
I have no idea what I am doing using this file attachment method. I think it worked.
Thanks #3 is the hose that comes out of the engine bulkhead directly behind the engine on the starboard side looking at it, and is accessible without taking the big panel off. There is about 3 inches of hose between bulkhead and the tee fitting in which you can pinch off the hose.I do carry a basic tool kit on board, and also a battery starter just in case. I would get a picture but right now I have the boat covered completely with a heavy tarp keeping it out of the Arizona sun.Ya did fine, your diagram showed up, winner winner, you!
Where you have #3 noted, the diagram obviously isn't gonna be to scale, but what's the distance between that valve and the Tee fitting that's shown in your diagram? Is that Tee in the engine compartment, or is that behind the bulkhead for you as well?
Secondarily, what's in your onboard tool kit? If you don't have one, you'll want one. Whether you want to go in there or not, you're still going to want tools to take off those 15 screws. Maybe not for something like this, but you'll want to have those tools on hand in case something terrible happens. For instance, if your scupper drain is in there, and things go sideways with that thing, you may need to access that area. Wrenches, a small socket set, multimeter, etc. There's no way to know what you'll need, but some basic stuff will get you access, and perhaps someone else will come along with what you need, or be able to help out.
