Rogandanny
- SX
Hi all,
I am having some sort of electrical issue with my 2020 Yamaha SX210 related to the starboard motor. When I put the key in the ignition and turn it to vertical position (which powers up the connect screen/electronics), there is no response/screen does not turn on. When the key is fully turned the starboard motor does not turn over whatsoever.
The starter relay is good, and there is power going from the engine to the relay. I was able to Hotwire the engine and it kicks on immediately so it is not an issue with the engine.
It seems like it has something to do with the ignition not sending any signal to the electrical systems? Has anyone had a similar issue to this or any possible causes/ solutions? Thanks a lot
