drewkaree
- West Allis & Fremont, WI
That's super helpful info right there. To me, it demonstrates that the manual IS correct, that you should extract from both points, in order to get as much of the old oil as possible. The middle hole seemed like it wouldn't be too fruitful, but that's good to know your experience with it. I dunno what the oil passages are like, or how they're set up, so as to require extraction from both, but it DOES explain why the manual states to split the filler oil between the two openings. Good stuff!
- I extracted from the oil extraction hose (pink in picture at top) first.... 2 quarts came out
- I then extracted from the right most oil fill hole (red).... 1 quart extracted
How was your experience with the oil change? I know there are other engines that seem to require the absorbing pads and other measures, but I was kinda surprised that it seemed to be such a clean process on the TR-1. Given how well the extractor worked, I'm wondering if I even need to warm the engine up, but I know that might not be the case for every person's method of extraction.
