drewkaree
- Central WI
Do you have some mysterious leak in your boat and you can't figure out where it's coming from? Well, if you found this thread from a search, you're trying to track it down, and you've maybe even taken a look in there to see what people might be talking about, and if your boat is affected. My money is on EVERY one of the models that have an anchor locker drain having this issue with varying degrees, with the best situation being that the fitting juuuuuuuuuuust reaches inside the anchor locker.
I've removed the piece inside my anchor locker that would support an anchor that fits the location. I don't use that type, so I removed it long ago, and noticed that there's an issue with the drain. A search around here shows the fix for many. I saw @Yambers fix, and he shared the info on where he got it from. I did one more thing before making a purchase, and you should too. Remove YOUR anchor locker drain fitting and measure what's already there. I have seen info posted that simply does not match up with what I have, but that's not that person's fault, that may have worked for them. They may have needed to modify theirs, so that WOULD be their fault, as they did not note any modifications, sanding, or drilling that they might have had to do. Don't take my word for it, or anyone else's word for it, check your own situation, or be prepared to suffer the consequences of more work or returning parts or even worse.
My very own Amazon order directs me to the wrong fitting. Not sure if mine is the exact one that @Yambers used, but I bought an Amarine stainless steel fully threaded 3/8" thru-hull fitting. My Amazon order directs me to the correct type and manufacturer, but they do not show the size I used. At the very least, here's one that is identical to what I used:
The plastic thru-hull fitting on the outside of the boat was simply pressed in. The fitting looks to have been threaded, and they simply shoved it in, mangling the threads and using the threads as an aid to turn the fitting into a friction fit item - see the pic of the flange measurement to see what I'm talking about. They really boogered up that fitting, and you'll need to take into account that metal threads will require a bigger hole or a smaller fitting, and if you go plastic, you'll either need to find a gorilla to shove your longer fitting in there, or get a smaller fitting, or enlarge the hole somehow. There was absolutely no sealant anywhere on the fitting as well. Yours may be different. You may need a knife or blade to sever the sealant bond. You will need one anyway if you choose to follow my method, so you'll be prepared.
I used some painter's tape, an x-acto knife with a fresh blade, and some 4200 or 5200, I can't recall which one I used, but either should be fine. Additionally, I took some steps to shorten the stainless thru-hull fitting I got to replace the crappy OEM fitting which would require some additional tools. That's up to you if you want to do it. Some have, some haven't, it's your boat, make your own decision. I shortened mine so it wouldn't get caught up on anything I put in there. I'm going to be following @Sotally Tober's example and putting some fenders in there, since my Mantus anchor won't fit. If you're using an anchor that fits in the anchor locker, you might HAVE to shorten yours to get it to fit with the divider piece that goes in there.
If you have the divider in your anchor locker, remove it. Now you're ready to go. Get some plastic automotive body panel removal tools from somewhere. You CAN just use a screwdriver or putty knife, but the risk of gouging my gelcoat was enough for me to use what I believe is the correct tool for the job. It SHOULD take some effort, but yours might not, YMMV. Once it's out, measure the thing like I stated above. Don't take my word for it, but if it's close enough, you may want to risk it and follow my lead. You've been warned. Here's mine - diameter of the tube that is SUPPOSED to go all the way into the anchor locker drain, and diameter of the OEM flange. My replacement is better in every way. I forgot to get a pic of the inside of the OEM fitting, but it's 1/2". The metal fitting I'm replacing it with is 3/8" ID, because remember, they smashed the plastic one in. I could get an exact replacement 1/2" fitting, but I'd have to do some sanding to enlarge both holes to accomodate the metal fitting. I want ZERO water getting in, but for now, I'll settle for LESS water, I went with 3/8" ID.
Amazon.com : NRC&XRC Stainless Steel Barbed Short Straight Thru-Hull with Custom Gasket for 3/8" I.D (3/8") : Sports & Outdoors
www.amazon.com
