Newbie
- SX
Hello all,
I am a very new to watersports owner of a 2006 sx230 H.O. New like - first time on the water and first time boat owner yesterday. So Im fairly mechanically inclined, did my intial inspection and research on MR1 engines before I purchased, did the sea trial..everything seemed to beed good. Took the boat out for the first time yesterday for about 4 hours. Pulled out of the water , removed the drain plug and had about 3-4 of drain water, warm but not hot like off the engine hot. So I dug into the forum and joined. Thanks in andvace for all the help and support. My 1st question is that ammt of drain water excessive.. I did not run the bilge pump at all, I was told that it is not an auto pump and will burn up if left on while in the water. So question #2 is should I have that switch on while in the water? Thanks to all
