Eddie
- SeaDoo
- Other
2006 Yamaha AR 230 High Output (LOCATED IN SOUTH JERSEY) This Boat is Like New . You simply wont find a nicer one for the money . As a very meticulous owner has kept this boat under cover since NEW.
The AR230 is an exciting and affordable new jet boat with wake board tower which is designed for the family with water sports enthusiast.Thanks to her 4 cycle twin engines which deliver 320 hp she's quick to jump out of the hole, and with a long list of amenities, This is the best in class boat with the best marine engines madeShe's sure to keep you and your guests comfortable all day long.Key Features:- Twin 4-stroke engines- Yamaha engine Management System- Deep-V multi-chine hull- Walk-thru transom- Wakeboard Tower- Flip-up seats- Seating FOR UP TO TEN PEOPLE
CUSTOM MATCHING DUAL AXLE TRAILER WITH BRAKES THAT IS SIMPLY PERFECT AND LIKE NEW WITH RETRACTABLE TONGUE
NEW CUSTOM COVER
WAKEBOARD SPEAKERS AND CUSTOM AMP
Sellers Notes:Hours: There isn't an hour meter on the boat. I would estimate the boat to have less than 150 hours on it as it has only been used during the summer months and the last three years have probably added less than 20 hours. Maintenance: Since this is a Jet boat there was not much winter or summer prep other than adding fuel stabilizer during the winter and changing the oil filters and full service in the summer. All oil changes before going out for the first time each year. The filters were changed annually (all fluids and filters are new) Again the boat was only used a few times each year ON THE BAY IN KEPT ON A LIFT AT ALL TIMES INVIRGINIA.
Condition of the boat: 1) THE BOAT IS LIKE NEW NEARLY PERFECT. Boat is fully polished and detailed 3) Interior of the boat is in very good condition. Has Jet Boat Pilot Customer Cushion Inserts UPGRADE 4) Boat has always been used to pull skiers and intertubes, never used for fishing.5.)Jet pumps / wear rings ARE ORIGINAL AND LIKE NEW JUST BROKEN IN.6.) Every item on the boat works as it should Entire boat gone over recently. New steering cables ARE PERFECT 7.)Brand 8.) Trailer fully serviced and bearings and lights CHECKED and work perfectly This is a new listing and will not last a week!
THERE IS SIMPLY NO BOAT LIKE THIS IN THE REGION IF YOU WERE THINKING YOUR COULDN'T BUY A USED BOAT THAT WAS AS NICE AS NEW YOU WERE WRONG...THIS IS THE ONE!!! IT IS BARELY BROKEN IN AT HALF THE PRICE
If you are thinking of BUYING A YAMAHA AR230 go ahead and COME SEE AN TEST DRIVE IT today! Let's make a deal! I assure you that if you see and drive the boat YOU WILL BUY THE BOAT
IF YOU ARE VERY EXTREMELY PICKY AND WANTING A BETTER THAN NEW BOAT THIS IS THE ONE. LOTS OF UPGRADES THIS SEASON
I HOPED TO KEEP THIS BOAT BUT CHANGE IN PERSONAL CIRCUMSTANCES REQUIRE THAT IT BE SOLD OTHERWISE WOULD NEVER LET A BOAT THIS GOOD GO ........MY LOSS IS YOUR GAIN .....READY TO PUT IN THE WATER AND PLAY THIS WEEKEND
IMPORTANT I have provided you with a TRUE REPRESENTATION of vessel in EVERY RESPECT and will answer all questions FEEL FREE TO HAVE IT INSPECTED!
NEW CUSTOM COVER
