swatski
- North Caldwell, NJ
I so hope you guys figure out some consensus solution and post it here. In the meantime, I am totally on the fence about replacing my (whatever they are carslile?) bias ply tires with radials. The reason being - I noticed these trailers really drag those tires sideways during slow speed tight turns, which on hard pavement, like my aggregate driveway, can be a problem...
I think @Bruce addressed some of it recently here:
https://jetboaters.net/threads/radial-tire-belt-separation-can-cause-blowouts.10177/
For strictly highway driving, I think radials are the way to go, no question. But I noticed that when making tight turns, there are tremendous forces pushing the tires in these double axle trailers sideways. Depending on a particular layout, either front or rear axle can act as a pivot. Tires inflated to the max, trailer leveled, etc.
If I turn real tight the wheels/tires can end up sitting completely out of whack (I mean out of alignment with each other), toe in or toe out depending on a turn. When it happens, I pull up and down until it's back inline... But, it can be looking a little scary...
I have not looked into the suspension options etc. and don't know if that is because of the suspension type/tuning. Just wondering.
![20160821_155628[1].jpg 20160821_155628[1].jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/44/44488-e20db3d575c14a450b8929b248cd3deb.jpg?hash=4g2z1XXBSk)
