Buckeye Fan
- X
have you considered mounting it somewhere else?
I mounted my amp in the same location, up out of the way and you never have to worry about it getting wet.Yes, mount where I did in the port side storage area. Easy to run wires down the side. Use 4-gauge wire to supply power to the unit.
Yup my battery is in the stock location and route the power cable through the side compartment into the storage compartment. I would say it's about 8-9 feet of cable.How did you guys route your power cables? Are your batteries under port aft cushion? That's a long way away from power source.
Correct, the mounting board is screwed into the back of the bow seat which allowed for little bit longer screws.My batteries are under port aft seat. My helm is starboard. So are yours mounted under passenger dash area? If so how do you keep the screws from protruding into cabin. Looks like it's mounted right behind bow seat
Stopped by the storage unit to check on her today. While I was there I hooked up Fusion Link app. So I did a little sound check, and my lord. So here's a video of the hull flex. I'm going to have to winterize this weekend so won't be in the water for awhile, but when she does hit the water...... I'm pretty sure we will have a water dance going on around boat.
While impressive.......I will not settle for anything less than "Jurassic Park rings" in the water next spring
Honestly it's damn impressive for the stereo at this point!
Added the yamaha flush hose to get my hose outside clean out tray, but it's still not long enough. I'll get a little extension over the winter for it. Goal is to be able to cut hose off at tray instead of climbing in and out to house.
That's exactly what I have. However, it is still under the tray so I can't use it because the flush hose is so short. Just need an extension so the cut off is outside of trayCan't you just add a garden hose shutoff right there in between your garden hose and the flush hose? Maybe I'm not understanding what you're looking to achieve.
The guides are from a company called Fulton. 50" curved guides. The pads are from wakemakers. I have the pads super glued (thick) to the guides so they don't come offNice build! Where did you buy the trailer guides?
