HangOutdoors
- Royal Oak, MI
do you have an AK steering system on your boat? if so you can temporarily disconnect the steering cable that is locking up your system at both ends , at the helm and at the nozzle and run on the other cable until you can get a new one as my AK systems work both nozzles and the rudder from either or both steering cables, it is built in redundancy so if one of your cables failed completely the rudder and both nozzles still operates off the other one. IN this case the steering would not be hard to operate so using the boat would be a lot more comfortable while you search for a new cable.I did not try that one. Tried the air pressure cable luber and it only worked on one side - the good one of course.
I do have your system. That hadn’t even crossed my mind!do you have an AK steering system on your boat? if so you can temporarily disconnect the steering cable that is locking up your system at both ends , at the helm and at the nozzle and run on the other cable until you can get a new one as my AK systems work both nozzles and the rudder from either or both steering cables, it is built in redundancy so if one of your cables failed completely the rudder and both nozzles still operates off the other one. IN this case the steering would not be hard to operate so using the boat would be a lot more comfortable while you search for a new cable.
1/2” idWhat size hose you guys using here ?
17 sx210....first day on the water looks like I have the same problem.
When I move the buckets on the trailer, some black water leaks out of the one.
Thinking it's not worth trying to inject it with oil and I should just order a new one?
Also, what do I need the oxygen sensor tool for?
Yes, thanks...figured out what it was needed for.....I finished this project last month.....posted my results and info here https://jetboaters.net/threads/quick-question-steering-linkage.37849/#post-610197You use it to undo the bolt on the jet pump that the cable goes through.
Seafoam deep creep! Spray the steering cables that come out of the stern. Work the steering back and forth to allow the seafoam to work up inside of the cables. Do it for about 3 days straight. It should loosen up to factory specs. Also hit your gate cables as well. Spray it everytime you pull it at of the water. If the boat spends a extended period in the water use the seafoam followed up with marine grade grease apply it while wearing a latex glove!Today, I took the boat out into lake St. Clair to test out all the mods I have been working on. Also all the holes that I drilled and sealed. Everything passed with flying colors.
Unfortunately, as soon as we put the boat in the water the steering was very stiff. To be honest, I haven't been moving the steering wheel much so I am not sure when this started. I checked for debris or if anything is bent in the back and it is not. Everything looks good.
I do have CJS Fins on the boat, so I checked the additional Tie Rod and it is working smooth and vey moveable.
This is occurring while out of the water, in the water at no wake and at WOT. It was very hard to turn the wheel.
Anyone having this issue on this model and year? I saw some other posts regarding similiar on different models.
Any thoughts? Before I would just undue the steering cable at the jet and then check, for both sides and then check the nozzles etc. and go from there.
Listen! I live on the gulf coast and know very well about the steering cables and corrosives. Is is cheaper to buys some seafoam or spend $1000 to replace some cables? I’m sure service needs the money!That wouldn't have solved the issue, the cables needed to be replaced.
