2020 AR210 Stiff Steering
HangOutdoors
Royal Oak, MI
@AZMark Same with when I had issues with mine. Just worked on one side. Other one couldn't get it to lube up. So I replaced
Cobra Jet Steering LLC
Ok well try that and also check the bolts holding the two halves of the helm together some have come loose and had issues with the steering being stiff , worth checking on
one more trick while trying to lube the steering cable using a grease gun etc also have someone at the helm turning the wheel all the way in one direction and then to the other and try to visually inspect the cables for kinks or sharp bends.
I did not try that one. Tried the air pressure cable luber and it only worked on one side - the good one of course.
do you have an AK steering system on your boat? if so you can temporarily disconnect the steering cable that is locking up your system at both ends , at the helm and at the nozzle and run on the other cable until you can get a new one as my AK systems work both nozzles and the rudder from either or both steering cables, it is built in redundancy so if one of your cables failed completely the rudder and both nozzles still operates off the other one. IN this case the steering would not be hard to operate so using the boat would be a lot more comfortable while you search for a new cable.
AZMark
Phoenix, AZ
I do have your system. That hadn’t even crossed my mind!
Thanks!
well there you go "another option "
MilesPrower
While you're disassembling one of the fins so that you disconnect its jammed cable, you might want to consider this mod, which will allow you to disconnect, adjust, and/or replace your steering cables without touching the fins in the future:
A side benefit is that you can very easily align your steering once you make this mod. Just clamp straight-edges to the fins, so you can measure the spread of the straight-edges relative to the articulating keel. Then adjust the length of the cables and tie rods for your desired toe-in or toe-out angle.
I've modded three sets of Cobra Jet fins this way.
In order to align the nozzles properly you do it with the steering cables and tie rods disconnected and then the tie rods also need to be readjusted as for disconnecting the steering cable ,all you do is remove the small 6mm button cap bolt on the side of the fin and loosen the 8mm button cap about 1/2 inch to allow you to move the fin out and clear the bolt head on the cable. This only applies to the AK-19 fins as they sit further out from the nozzle to clear the reverse hoods width. The AK models sit in closer and are not in line with the bolt.
This way you are not compromising the strength of the fin where it attaches to the nozzle .
Here we are discussing eliminating the bad cable from the system until they can get a replacement cable, The second tie rod alone is all that is actually needed to interconnect the two nozzles and rudder and get everything to operate on one cable temporarily.
AZMark
Phoenix, AZ
@HangOutdoors did you remove the whole rear clean out tray to get to the starboard cable?
Did you put any sealant on the inside of the hull? My old ones were coated with like 1” of silicone.
HangOutdoors
Royal Oak, MI
Yes clean out tray was completely removed. Yes i used 4200.
Philip
Long Island NY
What size hose you guys using here ?
jamesk
PA
17 sx210....first day on the water looks like I have the same problem.
When I move the buckets on the trailer, some black water leaks out of the one.
Thinking it's not worth trying to inject it with oil and I should just order a new cable set?
Also, since it's the design that you can not access at the helm, seems like I would just be pushing water and debris back into it.
If I could inject the oil from the helm and get all the crap out through the stern I would give it a try for sure.
I have done too many projects that I spend hours trying to fix and than end up just replacing the parts and wish I had just done that from the start.
Seems like replacing it is the way to go but open to opinions, like from hangoutdoors....
thanks!
Also, what do I need the oxygen sensor tool for?
drewkaree
West Allis & Fremont, WI
Thinking it's not worth trying to inject it with oil and I should just order a new one?
To me, it seems silly NOT to lube it. If it works, great, you can put off replacing the cables. If it doesn't, great, you now have a cable luber for the new setup, you'll have experience with using the luber to maintain the new cables, and you'll have an idea of the importance of doing this maintenance on your boat.
Chin up, it's not headed to the scrap heap. Bright side and all
HangOutdoors
Royal Oak, MI
You use it to undo the bolt on the jet pump that the cable goes through.
jamesk
PA
Maduro
Crystal Beach, TX
Today, I took the boat out into lake St. Clair to test out all the mods I have been working on. Also all the holes that I drilled and sealed. Everything passed with flying colors.
Unfortunately, as soon as we put the boat in the water the steering was very stiff. To be honest, I haven't been moving the steering wheel much so I am not sure when this started. I checked for debris or if anything is bent in the back and it is not. Everything looks good.
I do have CJS Fins on the boat, so I checked the additional Tie Rod and it is working smooth and vey moveable.
This is occurring while out of the water, in the water at no wake and at WOT. It was very hard to turn the wheel.
Anyone having this issue on this model and year? I saw some other posts regarding similiar on different models.
Any thoughts? Before I would just undue the steering cable at the jet and then check, for both sides and then check the nozzles etc. and go from there.
Seafoam deep creep! Spray the steering cables that come out of the stern. Work the steering back and forth to allow the seafoam to work up inside of the cables. Do it for about 3 days straight. It should loosen up to factory specs. Also hit your gate cables as well. Spray it everytime you pull it at of the water. If the boat spends a extended period in the water use the seafoam followed up with marine grade grease apply it while wearing a latex glove!
HangOutdoors
Royal Oak, MI
That wouldn't have solved the issue, the cables needed to be replaced.
Maduro
Crystal Beach, TX
Listen! I live on the gulf coast and know very well about the steering cables and corrosives. Is is cheaper to buys some seafoam or spend $1000 to replace some cables? I’m sure service needs the money!
HangOutdoors
Royal Oak, MI
While I am sure you think your tone validates your solution, it does not. The cables had issues all the way through, actually one sided, it is known problem from Dometic whom manufacturers the cables. It was more than corrosion and I always suspected Manufacturer Defect. I didn't spend a thousand it was a few hundred, and the new cables work flawlessly. Additionally Yamaha has issued a NO SELL on boats right now that have cables and a mass recalls, dealers have been instructed to not sell/Deliver the models with steering cables, until the parts are replaced. Dometic has had issues with their cables for years with quality. It is a fairly seen problem by many. The most current one could be also a safety issue. I personally have done mine and helped multiple people replace theirs and the issue is always the same.
Rather than make do with a component that could have issues at anytime, and something so important as steering, I would prefer to replace them, which I did. Now with the issues that have been happening with Dometic, the manufacturer of our steering cables, I feel that replacing was the prudent option. Additionally, when I replaced mine, they were still very hard to get and if something additionally happened I may have been down for the season.
And while I personally replaced mine, for those whom need them/want them replaced it is covered under 1st year and extended warranties, especially now as more information comes to light about Dometic and their product.
