- Tranquility Base
- FSH Sport
Im not sure i follow. I power flush with a hose filled with corrosion x from the transom using an air compressor. I wrap a trash bag around the steering gearbox to catch all the material coming out the other end. with the boat jacked up, i often pull the little black boots down from the cables at the transom to let any trapped water to escape. does that make sense?
Totally makes sense! What type of hose do you slip over the end of the cable? I’m assuming that is what you do, with the hose already filled withe corrosion X?
