Yes! Very hard to find something with big enough doors to put this in! I got lucky!Congratulations!!!! Looks great! And she's living in a brand new home by the look of that storage!!!
Mines the same way, but everything is perfectly centered with the wheel straight on the trailer.Added the Cobra jet steering. I did something wrong.. the steering wheel is no longer centered to keep going straight. Otherwise works great.
CongratulationsMoney down in November and picked her up last month. Just broke in and did a top speed run of 46mph.
View attachment 150500View attachment 150501View attachment 150502
That’s easy to straighten. Unfasten the tie rods. Unfasten the steering clevis on both pumps. Put the wheel where it needs to be. Fasten a straight edge across the back of the pumps (6’ level or 2x4). Then rotate each clevis until you can attach them both. Reattach the tie rods. Make sure you do whatever toe-in is recommended for the fins. Tighten everything down. Blue locktite.Added the Cobra jet steering. I did something wrong.. the steering wheel is no longer centered to keep going straight. Otherwise works great.
What's the advantage of the cobra jet steering? Extra control? Waiting on the 212sd, if it doesn't come in, might look at 252 to order for next yearAdded the Cobra jet steering. I did something wrong.. the steering wheel is no longer centered to keep going straight. Otherwise works great.
They make the boat feel like it’s running on rails (extra control) and they help with reverse steering.What's the advantage of the cobra jet steering? Extra control? Waiting on the 212sd, if it doesn't come in, might look at 252 to order for next year
Definitely added better low speed control as well as high speed. I love the additional control and highly recommend. On a side note the drive models have electric steering so the steering wheel only turns the jets when the engines are running. I believe this where I messed up the centering of the wheel. Hooked it to the hose and started one engine... Moved the wheel back and forth then centered it. That's when I found out the jets and rudder were not lined up with the keel. Readjusted the jets and lines up much better now.What's the advantage of the cobra jet steering? Extra control? Waiting on the 212sd, if it doesn't come in, might look at 252 to order for next year
