Noviogonz
- Sugar Sand
- Tango Xtreme
Hi. I wanted to get ideas on options, solutions or what actions you suggest if in my position, when buying a used boat and currently cannot water test.  I just learned from the current owner that “he does not plan to launch the boat but can plan something out, but can start the engines with no risk.”
Back story: Am looking to upgrade from a 2002 Sugar Sand Tango Extreme to a 2022 Yamaha 212S with less than 75 hours. The boat is housed in upper Midwest (currently freezing and forecasted temps that day are low 37, high of 58) and is near my cabin, about 200 miles from my main home. The boat is priced reasonable on lower side based on ABOS. Reason for selling is they have multiple boats and realized for their lifestyle, a pontoon and fishing boat are what they use most and are not using this boat much. The seller is an engineer and seem trustable based on speaking and texting with him (very detailed on good (a lot) and the bads (a couple)).
Knowing I can visually inspect inside and outside, do a flush test, test electronics; should I still perform a compression test (with <75hrs?), or insist on a water test or ask for an assurance/guarantee (if so, can you give an example) or should I back off?
I appreciate your thoughts.
