- Buffalo, NY
Same boat, similar mods, same results.I have a 2017 AR190. It does slow down with a heavy load as well as with strong winds or anything other than perfect seas. To make it a little more powerful when pulling a tube or with a full boat I did - ribbon delete, remove air box and add larger air intake(K&N), and Lucky 13 cone. Ribbon delete added a few more rpms. Moving to a K&N made it a little more loud but gave a feeling of more mid range pulling power. Lucky 13 changed it to feel like more of a rocket when loaded lightly and more manageable when with a heavy load. Each boat is different with the spacers on the lucky 13 which takes trial runs to see what feels best to you. With all spacers I am at 38mph but top at 7200rpm. With only the smallest spacer I am at 7550rpm, top speed 37mph but it takes off like a rocket with absolutely no cavitation. I was on the quest to get above 40 and haven't had luck unless it is glass with the bimini top down. My next step is to repitch my impeller to give that a try.
If I were to only do one I would start with lucky 13 and then go from there.
I can get 40 with the Bimini up, but only in good to excellent conditions with nobody in the bow.
@Daryl123 If you're only getting 15mph with full people, something is wrong, or you're at significant (+3k ft) elevation. Most likely you have cavitation problems and are not getting adequate "traction" with the water.
