Bias tire rotation
dietz
Original Bias tires are more heavily worn on outsides. Should I be rotating them to opposite sides to double the life?
Thanks in advance
Also
242x. Should I be looking to go radial when I replace? If so, is there a preferred standard wheel & tire combo that looks nicer & is affordable? (If so, which website or package deal)
dzeppos
Coto de caza, CA
Thanks in advance
Also
Get rid of them. Night and day between radial and bias ply. Good year has a great radial tire which will ride better, safer, higher speed rating. I junked my bias tires after the first year.
marcham
Comox, BC
AR195
Thanks in advance
Also
That points to an alignment or spring problem. Have you removed the wheels and looked around for a worn suspension components?
Tjw961
Olive Branch, MS
Somethings not right if you're seeing that kind of wear. Radial Goodyear trailer tires is my suggestion, but any tire is going to have the same wear issue until you fix the root cause. Don't forget to swap out the spare to radial as well when you do make the change.
Tranquility Base
If each tire is wearing on both sides Of the tread, that’s under inflation.
I just switched out the stock Carlisle bias tires to Goodyear Endurance radials. The main reason I swapped tires was that the bias tires had the typical bias tire flat spotting when cold, but would not go away when warmed up… constant vibration while running down the road. The Goodyear’s are pretty awesome, smooth and vibration free.
SCP1
DeForest, WI
Thanks in advance
Also
By rotating you mean toss and buy radials, yeah!
dietz
Assuming you got new wheels too? If so, which did you go for & what size. Thanks
Tranquility Base
