Beachbummer
- Houston TX
- SX
Plug hatch safety switches prevent the engine from turning over so they're ruled out.
Like @TimW451 says...It does not work like you think... It has 2 circuits in there, one that fakes the boat is NOT in neutral - so it won't crank, and the other that fakes the key is in OFF position, so it will shut off if running.
Since it never shuts off on its own I suspect it's not the switch, but this info is important to know when troubleshooting, so I'm taking license to state it again. If I was you, I would bypass them to confirm it's not the switch, just in case.
Best of Luck!
