MrMoose
- Calgary, AB, Canada
Thanks @NeutronLooks great... very clean install
@MrMoose ...is the red plug aftermarket? What's the product info. I'm liking it. TIA!The red plug connects to the back of the plotter. It pulls out to connect to the plotter, and slides back in when I'm not using the plotter. I'll take a pic of the plotter installed tomorrow.
It's the cable/connector that comes with the plotter.@MrMoose ...is the red plug aftermarket? What's the product info. I'm liking it. TIA!
Did you find a submarine @Jon Burns ??Didn't want to drill into the console, so I use a RAM suction cup. Mount it right to the windshield. This is the only photo I got, but you get the idea.View attachment 50856
@Andy S, we had the wrong tools when we were looking for the sub in Bimini.If I remember correctly we spliced into the power to the 12v outlet. Not sure if it's the best thing but I've had no problems. I mounted the transducer on the starboard side in the pic below. And we did find a sub. https://en.wikipedia.org/wiki/USS_S-49_(SS-160)
The installation manual said to put it above the waterline. So I ran it up underneath the swim platform and used 5200.Where did you pass through the hull? Seems like most people are passing through above the waterline. I think it would look cleaner to pass through at mounting location. I don't see any reason that it can't be a watertight seal there
No fixed VHF@Jon Burns, do you have a fixed vhf?
@MrMoose .. I have a plotter and vhf to install.. I am going to run a power wire to a.distribution block behind the helm so I can power the plotter, vhf radio, and the nmea 200 back bone.. along with anything else I want to put there.
