96Pirate
- Wake Forest, NC 27587
Hi folks. So I have just about completed my Blue Seas add a battery install and was going to change the oil yesterday when while flushing I got the check engine light on both motors. No issues on my last run last year on the single battery. So thinking it has to do with my wiring. I used the following diagram that was similar to one that Mel @txav8r put together (Thanks Mel!)
Everything was hooked up with the exception of the following...
Ground from ACR to busbar...hooked that up today and same issue
No fuse between battery and switch on house battery
No amp install yet so 4ga + and - connected to switch but no further
The one thing I can think of that may be causing it is I have the stock accessories tied in to the house side of the switch and without that fuse there is no power there. So how are the gauges wired in and could this be causing the issue?
Here is my setup minus the ground from ACR to switch. I just added that today.
Here are my connections to the switch...
Top right - ACR, Engine 1, Engine 2
Bottom right - Starter battery
Bottom left - House battery
Top left - ACR, Accessories, Amp
Thanks in advance for the assistance. I was hoping to get her out next weekend but need to solve this first.
Mike
Mike
