FSH 210 Sport
- Tranquility Base
- FSH Sport
I just made this same post in my surge brake actuator thread here. https://jetboaters.net/threads/changing-out-the-surge-brake-actuator.41582/
Just wanted to shoot up a flare to the group about doing a simple check that could save you a lot of grief. Take a pry bar and gently move the calipers to make sure they are not hung up in the rails. As with most things mechanical the biggest problems come from lack of use, and brake calipers move very little if any in their rails during normal use.
So in addition to check the fluid in the master reservoir, and using a screw driver to manually actuated the brakes to make sure they build pressure with no sponginess aka work when applied, you should check to make sure the calipers slide freely in their rails.
By using a pry bar such as this…
you can gently apply the amount of force necessary to get the calipers to move in their rails. Once you have collapsed the piston and have some play, move the caliper back and forth several times to make sure it will move freely. After you are done with one caliper go to the tongue and pump the brakes up manually using the manual actuation port.
Pump this lever until you feel the it come up solid with good pressure, this will move the fluid you just pushed up into the reservoir when you collapsed the caliper piston. If you don’t you will push fluid out of the reservoir making a mess and then there very well could not be enough fluid in there when the brakes get pumped back up. Repeat the same steps on the other caliper and you can be assured that your calipers will not be hung up causing a real issue when towing on the highway.
