mraz72
- Rochester, NY
- 242X E-Series
I completed the install yesterday and I had a few questions I hope someone can help me with.
Kit - Blue Seas Add a battery, 120A
1. I mounted the switch and ACR under the port side rear seat (where the original battery is) I am concerned that the cables are too close to a fuel line, here is the picture
Is there something I can wrap the fuel like with to protect it? That black tube says fuel on it
2. How can I get the radio to run off of the house bank. I believe I know the answer, just checking to see if I am correct. In the pic below, you see the stock switch, there are two positive cables on one terminal, one goes to the engine, the other goes to accessories (the one labeled B1)? I am guessing if I moved that cable to the house bank, that would be the solution. BUT, does that also contain the bildge? Should I move everything to house?
