djetok
- Edmond, ok
- Boatless
- SX
I would suggest a lower gpm pump. 1.3 gpm (gallon per minute) pump will die a almost certain death if you run it for a period of time. Your shoving 1.3 gpm into the line with only about a 1/4 gpm of nozzles.Here is a flow chart. This will give you accurate water use.I have not had to run it yet, outside of testing as it hasn't been hot enough in South Florida. I probably wont need to turn it on till April or May. According to my calculations I will run out of battery way before I run out of water but no real world data on that yet. Below is the Amazon links for everything I purchased.
Nozzle-Droplet-Size-and-Flow-Rates-Sara-E.pdf (cloudburst.com)
