Doing the same project this spring. Where you planning on adding the 6.5? I wish there was enough depth on our boats behind the black side panels to add them there but not having the boat and searching the forum looks like most on our size boats add them down low in the fiberglass.Thanks all. I have a jog saw and will out a fine blade for them.
I was going to put them by the driver and across but today I changed my mind. I am going replace all 6 Polk with clarion, the sum and amp I think it will be good. If I have to put the additional pair after I will.Doing the same project this spring. Where you planning on adding the 6.5? I wish there was enough depth on our boats behind the black side panels to add them there but not having the boat and searching the forum looks like most on our size boats add them down low in the fiberglass.
I don’t think it matters what speakers you have if they aren’t pointed anywhere near your ears. Huge mistake by Yamaha to not include mid cabins.I was going to put them by the driver and across but today I changed my mind. I am going replace all 6 Polk with clarion, the sum and amp I think it will be good. If I have to put the additional pair after I will.
Thanks. Do you have a sub? If so where do you put it?Im Smack dap in the middle of a stereo upgrade/refresh. Replacing the stock DB651’s with MM652’s and they fit in the current holes but we also added 2 more in the cockpit.
We used a 5” hole saw with the area tapped up
And a shop vac going for the fiberglass and the hole saw was perfect! Absolute beautiful circle and the speakers slide right in.
I would highly suggest a hole saw for whatever speaker you use. Perfect circles. Just hold on to the drill nicely so you don’t break a wrist or get shards of fiberglass or metal shaving your hands like @AZMark!
Make sure the speaker cover will conform to the spot you are going to place the speaker. Someone here put a sub in and the spot was a bit curved. They had to seal a gap between the cover and the boat.
