Did we damage an engine?
bthessel
Lebanon, OH
So yesterday after running back to the ramp my wife dropped me at the dock and I went to get the truck. She sucked up a large branch at that point in one engine. It jammed the impeller hard. Do to the chaos around the ramp and that she was just at idle speed while I was getting the trailer she didn't hear any thing and the engine overheated and stalled. Happened quickly since the engine was hot from the run across the lake. She didn't try to restart it thankfully and we got it out on the trailer. After pulling the pump to get the branch out the motor started up and sounded fine.
Is there anything I should check further or do? Just run it next weekend and keep an eye on it?
BigN8
Corinth, TX
Do a close inspection of the impleller and wearing ring. Also the sealant around the wearing ring and intake grate. If you damaged the impeller or gouged the wearing ring your pump will cavitate next time out. Cavitation means you will have power to the pump but noticeable decrease in torque and thrust.
scokill
Rowlett, TX
Sounds like you will be fine. If you want some peace of mind you could run it on the hose. Engine on, water on, water off, engine off. Otherwise run it and keep an eye on it.
Bruce
Royal, AR
It is very unlikely that any harm was done. Just go back out and enjoy her.
haknslash
Lake Martin, AL
Moomba
I doubt you did damage. There are images on here of some pretty unreal things people have sucked up. The overheat was likely because the impeller couldn't effectively provide the thrust needed to supply the cooling system inlet strainer which is located past the impeller in the pump housing. As @BigN8 said I would inspect the pump housing for any gouges in the ring or missing sealant around the intake grate and in the pump tunnel. Also inspect the impeller for any dings or wedged pieces of the branch stuck in the blades.
bthessel
Lebanon, OH
So an update, apparently the heat from the engine melted holes in the water manifold tubing on the outlet.1497044569659472198727.jpg
Found out after putting it in and water was spraying in the engine compartment.
Going with a temporary fix for the weekend till I can get a replacement.
0627Devildog
Classifieds Moderator
Acworth, G.A.
Your temporary seems like an upgrade. Nice fix!
I know right. . . . . got me here thinking I need to add that to my MODLIST. ;)
bthessel
Lebanon, OH
It's definitely not going to melt, $26 in plumbing supplies and we should get back on the water. Also found out at some point in the last 2 outings my bilge pump stopped working. So thats on my list now to check tonight
Scottintexas
Corinth, TX (DFW)
Great fix, I don't think we've ever seen anyone melt that before,
Be sure to check your scupper,
buckbuck
Texas
I recommend you change the oil in that engine and keep a close eye on the temps using a infrared gun. I have ended up with a engine with little or no cooling water a number of times but have never had an exhaust manifold get that hot. To me, that is an anomaly that none of us has experienced before.
tdonoughue
The Woodlands, TX 77381
'No, but I stayed at a Holiday Inn Express last night...'
Seriously, very nice fix/upgrade. I wouldn't go back to OEM on that one either.
GTBRMC
Waukesha, WI
Per @buckbuck 's comment, I don't recall anyone ever experiencing that failure mode. I am concerned that your engine didn't go into overheat protect mode... that should have happened well before damaging (let alone destroying) the manifold.
I am sure someone with more knowledge in this area could give you specifics, but I would hunt down and verify the overheat sensor(s) on that engine are working.
bthessel
Lebanon, OH
So today I ran the boat after putting those parts in everything seemed great but as I was testing it I noticed when that engine gets up over 8k rpms it is cavitating, you don't notice it really with both engines running but just throttling that one up you do. I pulled the pump and it does look like I have some scratches from where the tree limb spun in there. I didn't notice them really the first time I pulled it apart and hadn't run it hard enough to notice it. I am guessing that is the cause.
How hard is it to change that ring and where is the best place to get a replacement?
Gonna pull it back to the house this week instead of leaving it at the lake and try to fix it and also replace the bilge pump and check the scupper more. The bilge pump clicks on when you flip the switch but doesn't pump water ever all of a sudden.
Seadeals
Greenville, South Carolina
Did you lose any top speed? Do you feel/see the cavitation (RPM) on just that engine when launching with both engines?
bthessel
Lebanon, OH
I don't feel it on both engines when launching, only if I am at idle on the one and throttle up that side. If I push both up over 8k rpms you see it on the tach and feel it. But I don't really notice the loss of speed. I need to test a little more.
Seadeals
Everyone offers great advice here. For what it's worth, if I were in your shoes, I would fix the bilge pump as you plan and not worry about the pump cavitation. Keep having fun with it through the summer unless something else changes. You can pull the pump and take a closer look over the winter.
Noko
Lake Nokomis Wis
Gonna pull it back to the house this week instead of leaving it at the lake and try to fix it and also replace the bilge pump and check the scupper more. The bilge pump clicks on when you flip the switch but doesn't pump water ever all of a sudden.[/QUOTE]
Is the bilge line clear? I know mud dubbers can build mud nests in any opening.
bthessel
Lebanon, OH
So would this level of scratches in the wear ring cause the cavitating?
