Summers420us
- 242 Limited S E-Series
Can someone take a crack at explaining all the drain plugs and how to properly utilize them?
I see the anchor locker has a drain without a plug, then there is a drain with a plug in the ski locker, the gas tank area, and the engine bay. Also two drains with plugs on the outside at the stern.
Are these only for wash out? Are there more plugs? When should they be opened? The fuel tank area is tough to get at, does that really need to be opened much if ever?
I seem to get about a gallon of water out when I drain the stern plugs, is this normal?
Thanks in advance.
Thanks in advance.
