props2you
- Round Lake, IL.
- 242 Limited S E-Series
Hopefully one of the electronics guru's can chime in! Whilst underway, key is turned on, house and start are both turned on (obviously). Now, while moored enjoying the day, it typically stays that way as well, but I was thinking, is there an advantage to turning the key & start OFF while moored? Should I be at least turning the singular ignition key off? Does the system shut down after a certain time limit just on house if only the stereo is on? Does it save juice?
