- Tranquility Base
- FSH Sport
I think all Yamahas come from the factory with the same pump and configuration. That is, the battery switch must be on and the bilge pump switch must be on as well. Once these conditions are met the bilge pump checks for resistance against its impeller every few minutes. If it detects water the pump stays on other one it switches off immediately after it checks. I rewired my pump so it’s connect directly to the battery because I anticipate renting a slip during the season. This allows me to turn off the battery but still keep the pump powered. I should also be able to turn the pump on and leave it on manually now via the bilge pump switch, you need to upgrade your pump to get this added functionality. My upgraded pulp has a third lead.
On my 2020 210 FSH Sport, the factory bilge pump was wired directly to the house battery with its own fuse for the auto function. Once the house battery switch is turned on there is a manual bilge rocker switch on the panel. My oem bilge pump dose not cycle to test for water, it has an integral sensor whether that’s a float or a probe I don’t know, I’m inclined to think it’s an internal float.
