CFD3Captain
- Coshocton, Ohio
- Moomba
- Wake
I saw this part and thought aawww thanks!
Thanks for the inspiration!!!
I went to Walmart with the wife just to see if they had the tint and how much. Was Planning to order from Amazon and use Wally World if I needed more or goofed up.
Ha! look what I left with.......for $15 TOTAL!! View attachment 18889
Warmer the better yes, because it dries out the soapy water you use and allows the tint to dry good. In cooler temps I've used a hairdryer to heat the outside of the window and that helps immensely.Thanks @ToddW850 It will probably be a few months before I attempt it unless I take the boat to the firehouse and do it inside. Still a little cold here and I am assuming the warmer it is the better?
I think you could have painted it and got the same results!View attachment 19456
Finally got the tint sorted. Double layer 15%. Let me tell you. This is DARK. haha
Sweet pics, however I have one question. Your screen name conflicts with your location!!I finally got my windows done. Don't regret doing it at all biggest advantage for me is when on the hook it keeps the heat out and is very private or when the sun is low in the sky driving into it. It also has kept the temp a lot lower on the dash! I went with 5% and had a guy come out to my house to do it for $300.
Here are some pics to show.
View attachment 19571 View attachment 19572 View attachment 19567 View attachment 19568 View attachment 19569
I guess it does. At the time it was accurate but now I moved I did not want to bother updating my screen name.Sweet pics, however I have one question. Your screen name conflicts with your location!!
Is a double layer of 15.....7.5?View attachment 19456
It would actually be 15% of 15%, which is about 2.25%.Is a double layer of 15.....7.5?
I would think road grime/debris would pit it in a hurry.I have a thought of putting the clinging tint on the outside of the boat windows. I think it would be easier to install this way. Any reason why I shouldn't.
