FSH 210 Sport
- Tranquility Base
- FSH Sport
I do not have this boat, so I am asking how water is getting in under the hatch and down into the locker? I totally understand the trailer part. Where does the deck water pool and leak in around the locker curbing/seal? Assuming that the source of water is not from wet gear. Curious.
The issue is that the drain channel area doesn’t drain properly, mainly because there isnt enough drop between the drain and where it ties into the main deck drain in the engine bay. Where water can get into the 5 gallon bucket locker is when drain channel is full (due to the drain not draining) and you open the locker hatch and some of that water spills into the locker.
