ReelFishingSWFL
 - FSH Sport
Hello my 2017 FSH 190 630 hours has an occasional hard start I can’t figure it out.. It happens sometimes during cold start but mostly after running for a while then sitting in a fishing spot for an hour or two then it takes 2-3 key cranks to start.. maybe ignition switch or lanyard sensor? Is anyone else experiencing this and what was the fix? Here’s everything I’ve done so far.
new ECM (isolated issue I was having so had to get a new one)
new OEM fuel injectors
new wire harness
new starter
new fuel pump
new block heat sensor
new batteries/connections
cleaned/checked grounds
clean out hatch bypass mod
compression test checks out
new spark plugs
thank you all for the tips in advance.
new wire harness
new starter
new fuel pump
new spark plugs
