stevenk2
Have a 2019 AR195, was doing a bit of prepwork getting ready for the spring season, and like an idiot overfilled the intermediate bearing housing with marine grease. My grease gun is too apparently too efficient, and I wasn't watching close enough - by the time I realized, it was too late, evidenced by a pile of blue-green grease under the housing.
I've searched tons of posts, everything from "no worries, you just need to clean up the mess with the excess grease", to "you need to take it into the dealer and have the bearing replaced immediately". I mopped up all of the excess grease, so it's clean in the hull at least, but my bigger concern is I go to run it this season and find that I've ruined the jetdrive and/or left gaps in the bearing seal where water can get in.
I would say that I greased the thing prior to running it last season (filled perfectly, no pile of grease that time), and I had it out in July at Lake Powell and in September at Lake Havasu, and noticed that on the first runs each time, the boat seemed to bog for a bit (a couple of mins) each time before returning to full performance. I do check the engine bay regularly when we go out, and did not notice any water intrusion, nor was the bilge running any more than it normally does. Since we don't use the boat much other than for those two trips each year, I attributed the performance lag to old gas sitting in the system for a few months. The boat is garaged, so it doesn't sit outside and wick a bunch of moisture from outside into the system either, plus I add stabilizer when it's going to be sitting idle in the garage for a period of time.
Is this something I can just continue to run and not be worried about, or did I ruin the intermediate bearing and need to have it replaced ASAP before I head out with it this spring? I'm reasonably handy with tools and have done work on the boat and my other toys before - if the bearing does need to come out and be replaced, is it a job that I could handle myself? Or should I just take it into my Yamaha dealer and have them take care of it?
Also, if it helps to know, the boat is pretty lightly used (56 hours) and has only seen fresh water; additionally, we don't leave it in the water and always trailer up at the end of the day. The engine bay looks brand new, with no corrosion or other indications of wear/damage anywhere (again, I inspect the thing very regularly, both in and out of the water).
I've searched tons of posts, everything from "no worries, you just need to clean up the mess with the excess grease", to "you need to take it into the dealer and have the bearing replaced immediately". I mopped up all of the excess grease, so it's clean in the hull at least, but my bigger concern is I go to run it this season and find that I've ruined the jetdrive and/or left gaps in the bearing seal where water can get in.I would say that I greased the thing prior to running it last season (filled perfectly, no pile of grease that time), and I had it out in July at Lake Powell and in September at Lake Havasu, and noticed that on the first runs each time, the boat seemed to bog for a bit (a couple of mins) each time before returning to full performance. I do check the engine bay regularly when we go out, and did not notice any water intrusion, nor was the bilge running any more than it normally does. Since we don't use the boat much other than for those two trips each year, I attributed the performance lag to old gas sitting in the system for a few months. The boat is garaged, so it doesn't sit outside and wick a bunch of moisture from outside into the system either, plus I add stabilizer when it's going to be sitting idle in the garage for a period of time.
