tdonoughue
- The Woodlands, TX 77381
@flyin_dutchman asked about how #trailer_brakes worked on another thread. That seemed a topic it's own, so I have started this. Unfortunately right now I have no pics, but I am sure I or others will add later...
A trailer beyond a certain weight capacity is required to have an active braking system. All of our boats (I think) came with hydraulic brakes that are activated by the weight of the trailer pushing against the vehicle when the vehicle slows. Just aft of the coupler there is a piston that compresses, just like your car compresses a piston when you push the brake pedal. Compressing that piston pushes hydraulic fluid down hydraulic lines to pistons at each wheel. The pistons push brake pads against rotors or drums to stop the trailer.
All that works pretty well, except when you try to back up the vehicle. If you try to back up, the piston compresses and activates the brakes on the trailer. For this reason, trailers hook to the car light system through the 4, 5, or 7 pin connector and sense the backup lights coming on. When those lights come on, an electrical valve closes and prevents the hydraulic fluid from going to the brakes, essentially shutting them off while you are backing. When you put it in drive, the lights go off, the valve opens and everything is back to normal.
If you don't have the lights hooked up, you can still back the trailer. However, first you must temporarily deactivate the brakes. The trailers of this type provide a little nickel-size key that fits in the side of the coupler. The key stops the coupler from compressing (thus stopping the piston from compressing and the brakes from working). There are some aftermarket caps that can go on top to do the same thing, as well.
#Brake_fluid should be checked periodically, just like your vehicle's. However, note that brake fluid absorbs water very, very well. And when it absorbs it, it stops working. So do not check in the rain, and if it is humid, check very quickly. The reservoir is under a cap on the top of the trailer neck, right behind the coupler. Pry that off and you will see below the reservoir cap. Unscrew that to see the level, which should be about 3/4 full.
Note that brakes are a closed system. Brake fluid does not get used or evaporate. If your fluid is low, refill it, but then you need to find the leak. You also need to check more frequently and be prepared to refill, because the level will continue to drop.
Ok, what did I miss?
