I did a bad thing but couldn't be helped.
Steelerville
jacksonville, Fl
I tangled a rope on the port impeller. I couldn't understand tangle and had to limp back on one motor. The problem is the wind and current was so bad that I was going no where at no wake speed. I had to throttle up to about 4500 rpm say 6-8 mph just to make head way. It doesn't appear I flooded the non working motor as we took it this weekend and it ran great.
The issue is now my fuel gauge doesn't work. All I get on the tachs is " fuel lvl" . I'm assuming a wire came loose? Thoughts?
The fuel Guage doesn't work with both engines running?
Doubt you have any water ingestion issue.
Just to be clear..if one engine goes you have to clamp the other one off by the "Y" fitting intake ? or at least you should do this
