Intermediate bearing
Patricko315
I’ve read through the posts on this forum regarding greasing the intermediate bearing. I have a 24 Ar250 that has the remote hose at the top of the engine that goes to the grease fitting. I’ve read about the dangers of blowing the seals in the housing if you overpack it with grease. I’ve read some are figuring out how many pumps of grease it would take to fill the hose to reach the bearing. I have no confidence that’s a good method and could easily see overfilling and blowing out those seals. Seems it would be easier to remove the hose and just fill from the fitting? Access is pretty easy to the fitting. I’ve also seen some are filling with gear lube, what’s the easiest way to fill with that method? Im at 20 hours and have also considered just leaving it alone and doing nothing. If the bearing is sealed why is it critical that space is filled with grease? Really don’t understand why Yamaha wouldn’t fill that space upon assembly rather than us do at the 10 hour inspection. Really seems like more damage can be done filling that space rather than just leaving it alone. Thanks for the continued help on this page.
The hose is for expansion.
FHS 210 Sport had a great post on this ................it's all in a light touch/feel on the grease handle..........this is how I add..... I pump 2 pumps on my bench......this gives me an amount my gun puts out and clears any air in the gun lines..........I pumped on zerk slowly, and at the end of stroke number one of my gun I felt it start getting hard on the feel. On the start of the second pump I felt it staying hard at the start.........I STOPPED before seal pop. VARY SLOW pumps to allow you to feel small difference in pressure.
Thanks!
Yes, just have to pay attention and don’t be a caveman when pumping grease in. It’s really too bad the design doesn’t include a fitting that can be removed to let grease out and you would know it is full.
The most important thing besides not over greasing this housing is to leave room for expansion, whether it’s grease or gear oil, leave room for expansion when the lube gets hot or it will push its way out.
The first time I greased the intermediate bearings I used an irrigation syringe (bought a bag of 60CC ones off of Amazon), pulled the plunger and put enough grease in it so when I compressed it there were no voids, put a zerk in the tip and then pumped grease in with my grease gun so I could measure the amount of grease going in per full stroke of the pump handle. Then added the amount of grease as prescribed in the manual to the intermediate bearing housing. This year I added grease with my grease gun by feel, then pulled the zerk on each bearing and using a piece of line trimmer line stuck that down in there to verify there was enough grease AND room for expansion.
So for you @Patricko315, for the first lubrication, I’d pull the hose off of the bearing housing (use a piece of trimmer line and check to see if there is grease in it while it’s open) and pump grease down the hose to make sure there are no voids / air pockets in the line, re assemble and add grease how I did the first time, on mine I think it was 33-35cc of grease. Is this a PITA? Yep, but it’s once a year and will take you maybe 15 mins total.
Make yourself one of these to make doing maintenance easier.
The bearings facing each other inside the housing must not be sealed or there wouldn’t be a greasing recommendation, therefore this area needs to be greased. If you’re hesitant have the dealer grease it, if they pop the seals then they own it. Have the tech show you how it’s done.
Going forward I’ll just pull the zerk and check the grease level before adding grease.
I’ve said this about the oil bath conversion of the outboard jet pump bearing, that set up doesn’t have the correct seals for gear lube, and I think the same is true about the intermediate bearings as well, if they were these systems would have been delivered this way. Several members here have had great success with converting the outboard bearings on the jet pump to oil bath, when they pull the cone the oil looks good, only one guy had a bit of water contamination, but I’ve also seen those members talk about the gear oil disappearing, well it’s going out the seals. Have a good look at the seals, the leading one, facing the bow, is set up to keep water out. These oil bath conversion members have a system and it works for them and I can’t argue with their success.
The other more important thing to me is that the EPNOC grease does not lose its lubricating qualities when water gets in it as the water blends with the grease in such away that there is no loss of lubrication-to a point of course, just like the water proof grease you use on the trailer bearings. EPNOC grease is a low viscosity grease that flows around inside the bearing cavity as the shaft is spinning at up to 8000 rpm. When I was packing the cones the last time I serviced them I was using a seal pick to stir the grease to remove any air pockets, as I stirred the grease it became like syrup and flowed, as well as sticking to the seal pick and tented as I drew it out.
Gear oil on the other hand is not tolerant of water contamination and loses the ability to provide lubrication once water intrudes into it, ask off roaders who got water in their differentials and then lost the diffs due to lubrication failure. So, if the maintenance is done as per the service manual (check every 100 hours for water contamination) the EPNOC grease works just fine. Heck there is a member here who had 750 hours on his boat and had never pulled the cones before and not only did he NOT have issues, and while the area under the cones was thin on EPNOC grease, it was pristine, he added new EPNOC grease installed new O rings on the cones and he was off to the races.
I'm convinced like FHS says the grease in the cones and bearings will last many years............In the future going to pull the jets every 2 years....NOT because I think the bearings need it...............it's the splines that need the grease long before the cone/bearing. My port shaft spline was virtually dry.... the Starboard spline had a small amount of lube but it was coal black.
Is the fitting pressed in or threaded? I have some leftover 80w-90 gear case lube from my Yamaha F300 would that work?
iI is threaded so it just unscrews and then screws back in and any gear lube will be fine.
I removed the extension hose and replaced them with M6x1.0 Zerks I got at Ace Hardware for $1.79 each.
When I removed the fitting from the bearing housing I saw no grease in the fitting. I added a couple of pumps. my boat has about 45 hours.
Do I need to reinstall the extension hose for expansion?
Do I need to inspect my seals?
@Cobra Jet Steering LLC How much gear oil should I add?
Put in a couple ounces I add a rubber line and close it off by folding it over and cable tie it. I never add grease so I can add a couple of syringes to it . I did my last ones when I purchased them close to 4 years ago . The idea is to avoid hydraulic force inside the unit and liquify the lubricant so it works better.
Yep I would reinstall the hose,
CJS runs in the salt and knows his stuff!
Careful mixing, most are fine, some synthetics may not mix well and cause a gummy varnish.
How much grease did the manual say to add? Mine was 30-33 CC if I remember correctly. As I said above I used a 60 CC irrigation syringe to know how much each full stoke of the grease gun handle pushed out then added the correct amount of grease. Just be sure to leave a good air gap in the bearing housing for expansion. Why would you need to inspect the seals?
I reverted to the original configuration after adding the oil. Except I left the upper end of the hose disconnected and zip tied a small bag to make sure the seal was intact. My thought being if the aft seal is displaced the water pressure in the duct will force water up the line and into the bag.
Thanks
Not so sure I like the bag idea, I would seriously doubt you have any issue I have seen some serious seal blow outs with grease shooting out around the seals. I suggest you fold the hose and tie it after you use the boat a few times use some grass trimmer line put it in the fitting down in to the body of the housing and use the line as a dip stick to see what the grease etc looks like , no sign of water in it you ok. If you blew out the rubber between the housing and the seals it will look like this
I saw no grease blow out.
I will run the boat for a couple of hours with the bag and then reconnect it as it was before I started this.
