Jet Pump Cone Grease amount
FSH 210 Sport
Tranquility Base
Two years ago I service the grease cones on my boat, I was behind one year on that service (boo FSH 210 Sport Boo). I remember the first time I pulled the cones that I thought there was not enough grease in them to be able to migrate up into the bearing carrier and into the front bearing.
Here is what they looked like in April of 2023 after I had serviced them in 2021. I had filled the cones up about 2/3 of the way with grease.
Port
Starboard
When I serviced them in 2023 I filled the cones up with grease after much thought and research, again my thinking was to make sure the epnoc grease was getting all the way up to the front bearing.
Here is what they looked like when I pulled them a couple of weeks ago in December of 2024.
Starboard
Port
Interestingly the port cone was still totally full of grease while the starboard cone had developed a bit of a void and a tiny bit of moisture in the grease.
So, being the way I am I went back and had another long look at the service manual to double check things. The service manual states .7 ounces for the space in the bearing carrier and the cone. For reference the cone will hold just shy of 5 ounces, so .7 ounces would be a drop in the bucket in those cones.
I called my “local” dealer in Bismarck to ask a mechanic what they did when they service them. The mechanics were off, but the service manager Tim said he would check with Yamaha corporate and get back to me. About 10 mins later he called me back and said that Yamaha said to fill them with grease.
Hope this is helpful
Here’s a useful tip, when you’ve filled the cones and want to check the fit so to speak, leave the sealing O ring off so it’s easy to put the cone on to see if you’ve got the right amount of grease in there. I filled mine about 1/4” from the top so that the nut is fully covered and the grease is just about to touch the bearing. If you try this with the O ring installed the air pressure will try to push it back off.
The oil seals at the front of the pump are oriented so that if the grease expands too much it will push past the seals.
I will review my service manual and service hour requirements for our 222SE.
.7 ounces, really? What is the melting point of the epnoc grease? Are they relying on the bearing getting really hot, melting the grease and then flowing into the bearing?
If more are following that service manual you’d think you’d hear about fried bearings all the time.
1.4 oz of grease in that space does seem a bit low volume. I'm not sure how that grease expands when it gets hot. I fill the cone up at least half way, but I am also using a slurry with synthetic gear oil, so it flows really well.
The bigger issue that I have noticed with my own pumps,is water intrusion through the forward double lip seal. The shaft really abuses this seal and like wise the shaft in return develops a groove which further promotes water ingress. With my own situation, I pull the pumps and inspect everything annually. I am already poised with all the parts, ie bearings, seals ect. to change them out when the time comes.
A quick internet search yields the results below.
I guess you have not handled this grease before, it is a very low viscosity grease that flows well even at room temp.. it also clings to metal.
No I have not. Haven’t read through the service manual either. Hence the questions. But sorry for asking. Carry on.
Is your info correct on your profile for your boat? I'm not sure how the SeaDoo's are serviced, but they may call for something other than this Epnoc - thus far, I've only seen it referred to with the Yamaha's and their cones.
Just an fyi... @FSH 210 Sport isn't being snarky, that's just him doing what he does every day, which is to provide the rest of us with some useful, detailed, and accurate information and knowledge because he likes to help. It's easy to read something into a message here that isn't actually intended or implied. Especially from a guy with a reaction score approaching 9000.
Sold the Sea Doo. Had very similar cones with grease in them. Never refilled them as the one time I pulled them apart the grease was like new. Boat only had 56hrs when I bought it.
Now possibly in the market for a Yamaha which is why I do research and ask questions. Would be our 4th jet boat and do my own maintenance on every boat I own.
Absolutely no snarkyness in my reply..
Do you have any pics of the work attempted? I've got a neighbor whose son inherited a seadoo like you had, and they assume since I have a jet, and see me doing my own work, I know about EVERY jet - they think they're all the same. They were surprised at a few differences I pointed out to them, but I'm willing to give them a hand if they're willing to undertake the job. One of the things I mentioned to them is to check the grease in anything that takes it, and that they really should jump on ebay or something and grab a service manual. Pics, if you have any, are often valuable
Not any really detailed pictures of the grease cones. A big bonus about these jets imo is they’re very easy to work on. A hand full of basic tools and you can disassemble most of the boat.
View attachment 230943View attachment 230944View attachment 230945View attachment 230946
That's very true regarding tools. The guy's dad has a shop FULL of tools, but his kids never cared at all about working on stuff, but now that he's got "his" boat, and he's seen the jet skis and my boat, he seems interested in taking care of what his grandfather left him.
I'm not sure if he signed up here, but I'll shoot him a link to your pics so he can see what it looks like. From your pics, it seems similar to how relatively easy the process seems to be, similar to the Yamaha's. The process is always the easy part to figure out and learn about, it's the work and effort and tips and tricks learned that are the variables
I believe those cones use a specific oil, not grease and they have a removable fill plug. You shouldn't have to fill the cone then install it. I could be wrong but all the seadoo watercraft pumps i have worked on have that option
You may be thinking of the Mercury sport jets, or maybe even earlier seadoo/Rotax pumps. The sport jets had plugs and filled with merc gear lube.
These that I pictured were 2012 MY. Just like the Yamaha’s FSH pictures, plastic cone bolted on with three bolts and just about full of grease.
Dont know why they would change it. The old system was great. Easy inspection for water intrusion and easy fill. And not a lot of failures that i saw
