Trevor Shipman
- Charlotte, NC
And let’s be honest, good or bad we all just want a reason to talk jet boating.
I was not sure for a moment if this was for real - the 500lbs wet steel shot bag on the swim platform thingy - or April Fools’...
Lol, I would have zero, none, absolutely no interest in hauling that much ballast in that fashion. Not just absurdly inconvenient, there are also liabity issues there, say if that were to slide off and something got tangled in a rope etc.
A polypropylene ballast bag filled with water does not sink, if it were to roll off, no matter how heavy.
@biffdotorg have you tried loading swim deck ballast right over middle of jets, one in ski locker and then moving people side to side?
Here you go guys and gals, sorry for all the delays. We're still working as you can see in the video but we're 95% there! I can't tell you how great testing went yesterday. Perfect weather, two boats, lots of boards, and the Thrust Vectors took a quantum leap about 75% of the way through the day!!! See for yourself:
Boat Info: 2018 Yamaha 212X (Nozzles Straight, rear bags full (800lbs) front bag empty, 4 adult male passengers (700lbs), full tank of gas.
Aftermarket Adds: Thrust Vector Wake, JetBoatPilot Ballast System (600lbs steel shot), GPS Based Speed Control System
During this shot it is important to know that we did not have to lean the boat or drive in a circle. We held the wheel straight and centered the weight of the bags and passengers.
You'll also notice the wake go from clean to foamy back to clean again. That is the reason why we are still testing. We've finally got all the pieces together to deliver a breathtaking product and we are now perfecting it. The clean wave you see in this video is what you'll get when we begin shipping hopefully late May 2019!
Thanks for your patience and for those of you who have pre-ordered, thank you for your business!!!!
Curious if like you say the boat is straight and all weight and ballast is centered why it appears the wake is only clean on one side and not the other?
Ballast was center of transom.Will, was the ballast centered, or off to one side on the swimdeck?
We found that balancing the weight was the key. No lean to either side. Even the ballast was centerline. Also we used no weight in the front. We added three bodies in the front and the wave got washy so we moved everyone back to the center of the boat.That's what I meant to ask in my question. As Will stated it was centered. Will, did you accomplish this by moving your people as there should be no reason for the asymmetrical wave otherwise. Just trying to understand what you did to accomplish this. And I bet you are trying to replicate it as well.
Cart is loaded on the Jetboatpilot store. This is the bait that may push me over the edge.
Our focus was only on the port side wake yesterday so we were not testing to clean both sides simultaneously. The final product will most assuredly clean both sides simultaneously because that has been one of our key selling points all along.Curious if like you say the boat is straight and all weight and ballast is centered why it appears the wake is only clean on one side and not the other?
