swatski
- North Caldwell, NJ
You can not have the Booster and the Wedge (both) on at the same time, they both mount on the surf side using the U-bolt tie down.I think the booster is trying to scoop more water into jets and make a bigger wave?
Wonder how it would work as the vectors are pushing down only what is being shot out of pump.
To me the wake wedge and booster might be better combo because of the large area in which wedge covers. My reasoning is that if the booster isnt able to scoop the water all the way over the wedge can clean up a larger area.. not sure if that even makes sense.
I said this before, it is possible the surf TVs in combination with the Booster will induce the delayed convergence effect, and it is possible it would be strong enough to augment the wake on the surf side and make a killer surfable wave:
Basically, the Booster would cause the hull to over-steer towards the surf side and then the jet steering nozzles (equipped with the surf TVs) would need to be pointed/steered towards the surf side (to counter-steer the hull) - possibly inducing delayed convergence and making a great wave.
(IMO)
Possible? Yes.
Likely? No.
Honestly, I would be quite shocked (but also elated!) if it all worked together like that. Keep in mind it is all completely empirical with those boats. Need water testing to know any results.
