    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
Loose Cleat
treeskier
Ocean City, MD
275SE
I have a loose forward cleat on the starboard side on my 2019 275 SE.
Does anyone happen to know what size the nut is (it’s big)? I am accessing it through the bow speaker hole which is not ideal. My hope is if I know for sure the size I can extend my reach with the appropriate size wrench.
I’ll take any advice on how to access it or a trick to tighten it. I was able to hand tighten enough so it wasn’t visibly loose but that’s not a long term solution. Thanks.
