YamaHog
- Little Rock, AR
- Limited S
So long story short, my last outing of the season 2 weekends ago did not go as planned. My dad & I went out on a local lake/reservoir so I could check the oil level on the water and run the boat one last time before storing for winter. They are dropping the level of this lake to remove hydrilla but we're pretty familiar with the lake and I know where the shallow areas are from my Navionics maps. Unfortunately, I ended up beaching my boat on a muddy/gravelly point at about 10 -15 mph ( a very good ways off shore). Luckily there were no big rocks and no fiberglass damage to the boat, just some nasty scratching down the keel from where we tried to rock the boat free. Some nice people from the Marina and fisherman finally got us pulled out of the mud and towed back in after being stranded out there for about 3 hrs total (sucked up rocks in the impeller).
I pulled the jet pump off and quickly discovered I needed a new impeller. So I have a new Solas impeller to install since apparently it takes over 6 months to get a Yamaha branded impeller. Since I'm replacing the impeller and sucked up rocks, I ordered a new Yamaha branded wear ring as well to replace it while I'm in there. Now on to the fun....
I know the impeller is reverse threaded and have been following Hoyt's thread here for tips (https://jetboaters.net/threads/2019-yamaha-195-impeller-replacement.37855/). However, I cannot for the life of me get the impeller to break free to remove it. I have the special tool from Solas that goes on the splines of the driveshaft to hold it in a 4 1/2 in Vise on my workbench. I've tried hitting a wrench with a rubber mallet to no avail, and I just bought a 5 lb sledge hammer and tried hitting a pipe wrench with that. This thing WILL NOT budge! I've tried putting all of my weight on the pipe wrench handle as well. Still will not move! I have to keep checking the Vise to ensure it's staying tight on the other end. At this point I'm pretty frustrated and at a loss at what to try next.
Would it be safe to try heating up the driveshaft/impeller with a heat gun? Any ideas or suggestions are much appreciated. I have to get this thing off to install the new one, and at the same time I'm hoping I don't rip the top off my workbench. Below are some pics of the damage and my attempt to remove the impeller.
As far as the scratching on the hull, I've started to do a little bit of wet sanding on it, but it's going to take forever by hand, and I'm not sure how well I'll be able to polish it laying on my back under the boat.....that should be "fun"......but for now I've got to get the new impeller and wear ring installed and jet pump re-assembled and back on the boat. Since I couldn't start it up after the incident, I wasn't able to flush the engine so I want to be able to run it for a bit on the hose as soon as possible in case theirs any dirt/mud in the cooling lines.
