FWBAR190
Good Morning All. Firstly, thank you for all the knowledge posted. I've learned so much over the last few days. I just purchased a 2017 AR190. As I'm going through the boat, I notice the cleanout plug won't turn. I read every single post about cleanout plugs on this site as well as the Yamaha Jet Boat site, and with that knowledge I was able to turn the plug and get it out. Again... thank you so much.
So, now with the plug out, I've cleaned it up, scraped off the dogs, scraped off the channels, coated the whole thing in marine grade silicon oil (again, thanks for the tip) but I pretty much have to use a tool with quite a bit of force to get it to turn back to the locked position. There would be no possible way I could do this by hand.
It appears there are two "manhole" cover designs (I hope I have that term right). The long handle plug (I have) and the short T handle design. I couldn't find any information on why the design change. It looks like most of the rebuild kits are for the shorter T handle plug. I did read on here that the gaskets will expand a bit, but figured that would affect seating the plug, not really turning it (could be wrong).
I guess my questions are, is it typical to be so hard to rotate in and out of the locked position, needing a tool to get it open? Would a rebuild kit help? The kit only looks like it contains the gasket and plastic housing. Should I try the T handle design? I'm not sure which one is the newer design. Or just try and buy a replacement for what I already have, the long handle design.
Thanks for any feedback you could provide.
