WiredKC
- Kansas City, Missouri
- FSH Sport
Check your filters!
I changed my oil last week and couldn’t figure out initially why oil was oozing out from the filter. I hand tightened the filter as I would normally do, yet when I checked after running, the filter was loose! Fortunately I didn’t run the motor beyond a 4-5 min idle before discovering I had an issue. Pulled the filter and found a plastic piece inside (see pictures).
Fortunately everything is running fine, but I had quite a mess on my hands, and things could have ended up a lot worse.
