jetboater4life
- Rochester, MN 55901
- X
I changed my oil yesterday. It was my second time doing it in 3 seasons of ownership. While my oil/engines were warming up I used the YDS software to get my hours readout. While sucking oil out of one engine I began the warmup/readout on the other engine. I used the incontinence pad under the oil filter and also used a gallon zip lock bag to remove the filters. Everything went smoothly and I had very little oil to clean up afterwards.
The day before, I was discussing this procedure with a friend, and he said that the dealer's around here don't warm up the engine before sucking out the oil. The reason they don't do that is because the oil filter is self draining based on the angle of orientation with the engine. They prefer to avoid the big mess when taking off the filter, and don't mind the extra time it takes to pull the oil out. This seems like a better way to do it, even though I managed to avoid an oil mess this time. However one slip up, and it would have been a coating of oil in my bilge like last year.
Now to my question.
What are your thoughts on this oil filter coming off with cold oil vs warm? Does it really prevent the mess?
Next time I do this I will do a cold oil change on the first engine to see how it goes.
I also fogged my engine and at the same time had @MarkB use a funnel and gravity to feed a gallon of antifreeze through the system. The time it took to feed the gallon of antifreeze through seemed just about the right time it took to fog all four cylinders. I pinched off my water intake hoses to make sure all the antifreeze didn't run out the inlet strainer in the pump housing.
Now to my question.
