I_squared_r
- Medellín, Colombia
- 242 Limited S E-Series
271 hours. I went up to Lake George this past weekend and the overheat alarm would sound if I idled too long. Water temp was 77F in some areas so it's a bit warmer than my home port. The pump strainer and thermostat look good. Good flow through the pissers. So I pulled the pump and found a little rope there. I'm wondering if this has been causing cavitation the past year. The boat cavitates a bit with 5+ people on board. Otherwise the pump looks great after 180 hours. Could this be the overheat problem? I'm taking the boat to NYC on the next trip and I'm trying to avoid an issue. I'm thinking the next step is to flush it with salt-away and hope for the best.
