David Martin
- Punta Gorda
- SX
Read the plugs today.................last plug read showed a problem and the Blackstone oil Analisis showed high gas content in the oil and the metals that showed up were rings and cyl wall wear.............the plugs show vary rich with on plug showing cyl wall wash down with raw fuel.............after injector cleaning using a injector pulsar and replacing the injector filter screen all looks great. The plugs are burning vary vary clean so the oil analysis should be clean as well on gas contamination.
I cant tell you how important a plug read is it can save your motor.............if I let the cyl wash down go for a year or two worn rings low compression ect...........The plug read and oil analisis 35 dollar was well worth it. Hear are the plugs before cleaning and after.
