Adrian @ JB Solutions
- Tampa Bay, FL
- 252SE
If I remember correctly, the inner housing actually has 5 bolts. One is smaller.If there are pry points they are very hard to see or get to it.
Not sure what you mean with the long bolts…. On this pump there no long bolts just 4 short ones for the pump and 4 short for impeller housing.
He needs to get that 5th bolt off, then he should be able to pry it off no problem.
Yeah 5th is off that is my bad. I will pick up a torch and prybar from harbor frieght and try again.
If that doesn't work then I will try screwing a 2x4 to the housing and tie a rope around it and pull it off.
What do you guys use to re-seal?
Pick up this pry bar from harbor freight. Works great when taking these pumps off for the first time.
I don’t think this would cause my RPM issues?
